RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 06-16-2008 | 05:29 AM
  #3259
cyborg1
Default RE: Nitro models pusher Bobcat?
Hi Boomerang1,
My retracts fold back towards the tail, they're 302 flat mounts. I got pix of the retract install from the other threads, and everything's all right at the moment. I was just wondering if anybody had the AUW of the bobcat with retracts? Mine seems to be a little on the heavy side. I also moved the servos to one side to get a central position for the steering servo. So far, so good. On the other hand, how many gear cycles can you get with 100 psi in the springairs? I am only able to get one clean cycle, and after that, the nose gear doesn't retract completely. Is this normal?
