RCU Forums - View Single Post - Powerbox Digi Switch Regulator & TP LiPo setup
Old 06-16-2008 | 11:17 AM
flyf3a
Default RE: Powerbox Digi Switch Regulator & TP LiPo setup
Hi
The digi switch has build in led that will give you indication of low voltage. On TP 1400 mah over 14 flights (electric plane) before change to orange. I will change plugs to micro deans or similar and charge directly. Have over 200 flights on TP receiver pack with switch combo and no problem.
Burt
