ORIGINAL: Nickolas
Hi there,
I am about to install a digi switch on my model. Please see the configuration attached. The switch is connected to the TP 2s2p LiPo back with a normal JR Female/Male connector. However I would like to check my voltage after every flight and also to recharge my battery without disconnecting the switch from it. I plan to interfere a JR Y lead between the switch and the LiPo pack. What do you think?
What are your practices really?
Nikos
It should work.
The Jaccio Perfect Switch Harness (with voltage regulator) has this cable built in to allow charging and testing the battery as well as a receiver DSC input connection and a means of connecting a binding plug to a Spectrum receiver.
Jim O
