RCU Forums - View Single Post - Powerbox Digi Switch Regulator & TP LiPo setup
Old 06-16-2008 | 11:56 AM
najary's Avatar
najary
Default RE: Powerbox Digi Switch Regulator & TP LiPo setup
ORIGINAL: Nickolas
Hi there,
I am about to install a digi switch on my model. Please see the configuration attached. The switch is connected to the TP 2s2p LiPo back with a normal JR Female/Male connector. However I would like to check my voltage after every flight and also to recharge my battery without disconnecting the switch from it. I plan to interfere a JR Y lead between the switch and the LiPo pack. What do you think?
What are your practices really?
Nikos
Hi Nickolas
I did exactly what you would like to have, but without a Y connector.
Take a look at post 291.
http://www.rcuniverse.com/forum/m_65...page_12/tm.htm
Regards,
Isaac Najary
