RCU Forums - View Single Post - Comp ARF Impact
Old 06-17-2008 | 02:50 AM
Andy P.'s Avatar
Andy P.
Default RE: Comp ARF Impact
Hi Jeremy,
As you say, the early versions had problems with the rear fuselage creasing, this was before the "fix" was announced (and I could show you the emails that formed the "fix", cheeky B&$t&rds) which came in the form of a central crotch or ladder down the fuselage. I should know as I was one who had this problem and if you have read the early posts on the subject, will realise that the problem was blamed by CARF as sloppy hinge points on the rudder which would have been installed by the end user. I won't go back into the too's and fro's of the emails I received, or the insults from AG but suffice to say that with the fix the model is fine. I eventually repaired my fuselage and installed a balsa ladder and since then no problems, in fact it's still going strong today, snap rolls and all!
I would say you won't be dissapointed with the performance of the model but it is a slippery beast and does take some getting used to, especially when it comes to slowing it down. On finals for landings don't be afraid to slow it right up, it will sit on the stall all day long with out any nasties, in fact I've seen gliders behave much worse at this attitude and speed!
All in all, if the price is right, go for it.
My twopence worth...............................well I am from the UK
Let me know how you get on.
Regards,
Andy.
