RCU Forums - View Single Post - Powerbox Digi Switch Regulator & TP LiPo setup
Old 06-17-2008 | 11:51 AM
najary's Avatar
najary
Default RE: Powerbox Digi Switch Regulator & TP LiPo setup
Issac,
I think the solution is there, thanks! Can you please explain a little bit? Have you soldered a cable in parallel to the female cable of the Digi Switch?
Issac I look forward to your reply, other inputs are more than wellcome.
Thanks again!
Nikos
Hi Nikos
Yes that is exactly what I did.
Regards
Isaac Najary
