RCU Forums - View Single Post - Do wrinkles in wing covering affect flight performance?
Old 06-18-2008 | 01:19 PM
Lafayette
Default Do wrinkles in wing covering affect flight performance?
Hello and I am a scratchbuilder. I am building an airplane right now and I am having my first experience with heat-shrink material. It is going pretty well, I am learning quickly, but it turns out to be I have 4 or 5 major areas with maybe 6-7 1 mm or 0.5 mm wrinkles in the wing covering. My question is, even with wrinkles would the airplane be able to lift off? Please don't post "repair the wrinkles" because I did as much as I could wihtout damaging the covering, just please say will the wing have pretty much teh same properties or not? Would the wrinkles affect the flight majorly ot the lift producedf? I know drag will be there, but since the wrinkles are at the trailing edge where lift is not present and air detaches from thew wing, will the plane fly pretty much the same as without wrinkles?
Thank you,
Yishht87.
