RCU Forums - View Single Post - Second RC Flight!
Old 06-18-2008 | 05:35 PM
homeunt
Default RE: Second RC Flight!
ORIGINAL: sixtyin3
I could pick up head speed but no lift.
Its the blade holder on the right in the pic.
I didn't notice anything else bent.
Also, my gyro has NEVER made the 3 beeps when I connect the battery? I think it should have. I guess I'll swap the Telebee on in the mean time while waiting on parts.
1. You really need to upgrade your motor, stock ESC and stock motor won't get you anywhere.
2. It's the feathering shaft that's bent. Swap it out.
3. Take your entire head set off the heli and see if the main shaft is bent.
4. gyro makes no beeping noisese. The initiation made by BrushLess ESC makes noises on BL motor.
Gee.. Dont you dare to lift off without completing radd's. You can do that only if you would like to pay about 100 bucks in repair and headaches.
I also suggest you to getyourself a bunch of feathering shaft, bell control armset and a pair of extreme plastic blades.
