RE: jet-1a air valve help
The Jet 1-A valve is similar to the jet Tronic. A friend has the Jet 1-A gear in his boomer and his nose gear will momentarily cycle when he turns the radio on. He has rebound his radio with the same results so it sounds as if the issue is with the valve.
