RCU Forums - View Single Post - DualSky 11T testing
Old 06-19-2008 | 01:45 PM
OhD
Default RE: DualSky 11T testing
ORIGINAL: shannah
Hmmmm. That is really interesting Jim. I may try to find one of these motors and give it a go. Since the newer packs will be fine running the higher output it shouldn't stress the packs too badly. I will probably want to rework some of my air ducting in order to accomodate the additional cooling required. Seeing as how I am one of the proponents to higher amperage faster flying, it might be worth a shot.
Thanks for the test session in the heat. Now, go back out and do it again.....
Steve
Yes, I meant to add that better batteries would provide even greater power. Think if they would hold 37 volts at 80 amps. I think I can borrow some TP Extreme V2s and see what they can do.
What are the best performing batteries these days? I've been looking at cost and weight and maybe I should be looking at performance.
Jim O
