RCU Forums - View Single Post - New Hull - Hardware Advice Please
Old 06-19-2008 | 06:28 PM
Steve441
Default New Hull - Hardware Advice Please
Hi - Here is the new 25 inch fiberglass hull I just got for $50. - I want to set this one up right with some help from you guys so any suggestions respecting the set-up are welcome. Is my idea that these water pick-up's (flush hull mounted) are better than through the rudder correct? - What is the best drive hardware (for the value) for this boat in your opinions (which I highly respect). I want to go 3/16 shaft so I can have a good prop selection with a generic (cheaper) brushless motor and 60 Amp Pulso boat ESC - Thanks for all comments and help - Steve
ID:	974210   Click image for larger version
