RCU Forums - View Single Post - New Hull - Hardware Advice Please
Old 06-20-2008 | 05:32 AM
pompebled
Default RE: New Hull - Hardware Advice Please
ORIGINAL: Steve441
What about the water pick-up for cooling ESC an motor - Is the flush hull mounted pick-up better than rudder pick-up?
Hi Steve,
Both a rudder pickup and the 'flush' mounted one have a certain amount of drag, as has anything sticking out from under the hull.
If you have a temperature sensitive set-up (on the edge, so to speak), the rudder pickup is my favourite, as it ensures flow through the system at all times, exept when you flip the boat.
A truly flush mounted pick-up, would be a brass or aluminum pipe facing forward as a pick-up and a second one facing towards the transom as outlet, both sanded flush with the hull.
This is a pressureless system that has virtually no drag and generates flow at all times.
I use a spray pick-up on my fast electrics, where the pick-up sits in the propspray in the upper right quadrant, seen from the rear.
The propspray has an average pressure of 2 Bar, so there's always flow and very, very littte drag.
Take your pick...
The faster your set-up, the less drag you'll want, to avoid handling issues when approaching the hull limit.
Regards, Jan.
ID:	974610   Click image for larger version
ID:	974611   Click image for larger version
