The picture you show is a electro-magnetic-coil, not a bobine.
A bobine don't have iron ends to follow the magnet of the flywheel.
Your coil need the magnbetic of the flywheel to generate the HV.
If your using a CDI-ignition, you don't need the flywheel anymore.
