RE: 10C
If you have models saved on a CamPac that you've been using in your 9C or 9C Super transmitter, you can plug the CamPac into your 10C and use those models. Save them to the 10C and then double check the functions. For safety's sake, some mixes may be set to be inhibited, and you'll have to turn them on. The settings, though, should still be there.
DO NOT reformat the CamPac when you insert it into the 10C. If you do, you'll lose everything that's on the CamPac.
