RE: Tiger 60 Build Thread
Bwolfgang,
Thanks for the tip on the tail wiggle. I took your advice and glued that last piece permanently into the hole.
The other significant mod I did is to rotate the engine so the muffler hangs underneath the fuse and points straight to the ground, and then put a cowl on here. Here are some current photos. I still need to build the tail structures, sand everything, cover, etc. Think I'm going to cover in all white, and then paint on the pattern.
Tom
