RE: How do you program the RipMax Extra ESC?
Well... going by the steps i should have been in the programming mode. I looked on both sides for a light flashing or on and saw nothing. There are several small blocks on the ESC but nothing i could see was a light. I will try and go through it again and see what i get. I will also try the spinning prop method to see if the brake is on. I was also thinking of putting it in front of a fan when it is running and then shut the throttle down. I should immediately stop right?
skeeter
