Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
 How do you program the RipMax Extra ESC? >
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 06-21-2008 | 10:54 AM
skeeter_ca's Avatar
Default How do you program the RipMax Extra ESC?
Ok, here it is as promised. The instructions below are what came with the speed controller. I am trying to turn on the brake but i cannot tell if i,m in the proper mode or cannot tell if it worked. The only way to verify it as i know is to fly the plane. I do not want to do that because the last time i did the prop was still turning when i slid it in for a belly landing (no landing gear on my glider) and it broke the prop and bent the motor shaft. The instructions say to watch the LED light on the speed controller. My controller does not have an LED light. It only makes the motor beep. Does any know how i can verify the ESC has the brake set on. Any help would be appriciated as my son and i want to take it flying.
Initial setup
1 Turn on the transmittier and place the throttle stick roughly in the middle position
2 Check that the speed controller switch is off and connect the battery
3 Turn on the speed controller if it has a switch
4 Place the throttle stick in the closed postion. The speed controller will beep once.
5 Immediately move the throttle stick to the full power position. The speed controller should beep twice to indicate the full power position has been set.
6 Move the throttle stick back to the closed position. The speed controller should beep once and then tree times to indicate that it is ready to work.
7 From now on, if the throttle position is kept at the low position during turn on the controller will beep once and then three times and will be ready to use.
Note: It is only necessary to make this initial throttle setup again if you are using a different transmittier or the settings have been changed.
Programmable mode setting
(brake on or off / battery type / motor rotation)
1 Turn on transmitter and place stick at closed throttle
2 Turn on the speed controller
3 The speed controller should beep once
4 Immediately move the throttle stick to the full power position, the speed controller will read this position
At this time:-
A) if the throttle stick is moved back to the closed position within 10 seconds, the full power position has been set, the speed controller is ready to use (see initial setup)
B) If the throttle is still placed at the full power position for over 10 seconds, the speed controller will beep multiple times and the LED will flash once constantly to indiacte the speed controller is now in the programming mode setting.
Flashing repeatedly once enters the brake on or off setting. 3 different program features can be setin the controller. (brake on or off / battery type / motor rotation direction) Every time the throttle stick is moved from the full power postion to the closed position and again to the full power position the programming mode will change. The LED will flash in accordance with the features as follows
1) LED flashes once (brake on or off setting available)
2) LED flashes twice (battery type setting available)
3) LED flashes three times (motor rotation setting available)
At the selected program function to be changed, if you wait for 2 seconds at the closed position the speed controller will beep to indicate that you can now change an existing parameter to a new parameter. In order to change the existing parameter move the stick to the full power position. The selected parameter will indicate as follows.
1) brake on > LED on, brake off > LED flashes
2) battery type > LED on for lipo, LED flashes for nicad/nimh
3) motor rotation direction : forward > LED on, reverse > LED flashes
After setting the required parameter, move the stick to the full power position and then wait for 2 seconds. The speed controller will beep to indicate the selected program parameter has been stored in the controller.
At this stage , if you want to change another program parameter, repeat the procedure above, or if all settings are complete, turn off the speed controller.
skeeter
Old 06-21-2008 | 11:57 PM
Default RE: How do you program the RipMax Extra ESC?
Ok skeeter.
How far in the Programming you stop? What make you belive your controller does not have an LED light? You know the LED is not round like a dome like the one you usualy see everywhere. On the ESC it look more like a smal block on the board. The instructions said that the LED will not flash until the speed controller is in the programming mode setting. If your not getting to this point maybe the ESC is not reading the throttle stick movement, check the endpoints off the stick on your Tx.
You dont have to fly the plane to verify if the brake is on after you do the programming steps just hold the plane in your hand or ask for help to hold it and apply power and then go to idel if the prop stop sudently the brake is on if keep spining then you know.
Fernando
Old 06-22-2008 | 11:18 AM
skeeter_ca's Avatar
Well... going by the steps i should have been in the programming mode. I looked on both sides for a light flashing or on and saw nothing. There are several small blocks on the ESC but nothing i could see was a light. I will try and go through it again and see what i get. I will also try the spinning prop method to see if the brake is on. I was also thinking of putting it in front of a fan when it is running and then shut the throttle down. I should immediately stop right?
skeeter
Old 06-23-2008 | 12:52 AM
For what the instructions said you will be in programming mode when the LED start to blink. Dose the speed controller beep multiple times after you placed the throttle at the full power position for over 10 seconds? If you dont see a light try to move your throttle trim all the way down and try all the steps again.
To check the brake just plug everything like your going to fly hold it give power to the motor and as soon as is moving pull it all the way down it should stop if is on. Yes, it should stop if the brake is on as soon as you move the throttle down.
Fernando
Old 07-08-2008 | 04:20 PM
skeeter_ca's Avatar
Ok............
I finally got it to go into the programming mode for sure. And yes i found the little tiny isty bitsy blinking LED light. Even after i knew where it was i could not tell it was an LED when it was off. Learn something new every day. After that i just followed the wierd throttle up-throttle down instructions and it worked. Thanks for the help.
skeeter
Old 07-09-2008 | 01:02 AM
Im glad to help, feel free to ask any other question. Have fun.
Fernando
