RCU Forums - View Single Post - DX7 engine cutoff switch
Old 06-22-2008 | 10:28 PM
Charlie P.'s Avatar
Charlie P.
Default RE: DX7 engine cutoff switch
Did you set the mechanical linkage to allow it to bottom out and kill the engine before you started playing with the digital trims? I always set my throttle connections with 100% stop-to-stop mechanical throw before I start to play with the digital trims and sub-trims.
I use throttle-down and kill on two seperate switches on my Futaba 9-C. Don't have any experience with a DX-7 or Spektrum.
Just an outside chance - this is not a gasoiline engine is it? They need a seperate circuit to ground the spark and not just a low throtte kill.
