RCU Forums - View Single Post - Pushrod Glueing- Having a problem
Old 05-11-2003 | 11:35 PM
rogwabbit
Default Pushrod Glueing- Having a problem
You mak also attempt to place a small piece of balsa in there drill a hole for the rod to go through, or use it as a spacer to seperate the rods... I do this on almost every plane makes the controls nice and tight... epoxy is the way to go.
