RE: Well got my first pattern Plane
Raising the head via head shiums lowers the compression ratio slightly reducing the tendancy to blow glow plugs due to the higher temperature the additional nitro content will cause; this is especially true on a piped engines.
In my case, running my ST X-61 with tuned pipe, on 3 engine runs I blew 2 plugs; not having head shims available, I placed a second plug washer under the glow plug achieveing the same thing as raising the head. I now have several runs on my ST X-61 and no blown plug yet.
So it seems to work. The only difference I noticed, the RPM's on the ground reduced by 165 RPM's, not enough to make a difference.
Orlando
