RCU Forums - View Single Post - Well got my first pattern Plane
Old 06-23-2008 | 08:21 PM
EpoweredRC's Avatar
EpoweredRC
Default RE: Well got my first pattern Plane
what kinda glow plugs are you using?
I have a quickie 500 with a speed webra 40 with pipe and never had a prob blowing glow plugs, but I do not use the cheap ones, use ones for racing type engines otherwise yes a reg one would blow every few flights.
ORIGINAL: crashlander
Raising the head via head shiums lowers the compression ratio slightly reducing the tendancy to blow glow plugs due to the higher temperature the additional nitro content will cause; this is especially true on a piped engines.
In my case, running my ST X-61 with tuned pipe, on 3 engine runs I blew 2 plugs; not having head shims available, I placed a second plug washer under the glow plug achieveing the same thing as raising the head. I now have several runs on my ST X-61 and no blown plug yet.
So it seems to work. The only difference I noticed, the RPM's on the ground reduced by 165 RPM's, not enough to make a difference.
Orlando
