RCU Forums - View Single Post - Go Technology engine question
Old 06-24-2008 | 01:03 AM
  #33
*FULL-REVS*'s Avatar
*FULL-REVS*
Default RE: Go Technology engine question
putting the extra shim in helps drop compression during break in... . just takes a bit of stress off the rod and beerings... remember to pre heat with a heat gun and you will be good as for fuel.... i believe its one shim for 20% and two shims for 30% i run both my GO's on 20% with one shim and OS P3 plugs and they run fantasticly.... hope that helps....
