RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Go Technology engine question
Old 06-23-2008 | 04:38 PM
Vigilante212's Avatar
Default RE: Go Technology engine question
ORIGINAL: sfar785
i got $130 in PayPal for a cheap motor for my 8ight buggy
[link=http://cgi.ebay.com/NEW-Go-Technology-21-3-Port-sport-engine-8ight-Tech_W0QQitemZ180255572214QQihZ008QQcategoryZ44028 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem]Go Engine[/link]
would that be decent for club races? I have an STS .28 or the Mach 427 for it, i just wanna try these Go motors that everyone raves about
It has alot of lowend. Youll need a pipe like the dynamite 086 to give it a bit more top end and maybe gear it higher. Should be fine.
Old 06-23-2008 | 04:39 PM
ORIGINAL: musclecar64
With my Go 3 port sport, I couldn't get it to respond until over 280 degrees. By then, I couldn't restart it because of vapor lock. Horrible engine. Worst $125 I have ever spent.
It was probably a bad carb issue.
Old 06-23-2008 | 04:41 PM
ORIGINAL: Vigilante212
Agree, early problem where due to the wrong material being used in the carb causing it to heat up like the head for example, which of course is bad. All sorted on recent engines.
Old 06-23-2008 | 05:02 PM
Umm, its been said over and over again... Go's like to run hot.
Old 06-23-2008 | 07:22 PM
I have the GO Tech .21 7 port Turbo... It comes with an extra head shim... Should i use it for break in? What is it for? Also, Can i run 20% fuel on this engine? Or should i use 25% or 30% ? And why? Thanks!!
Old 06-23-2008 | 09:29 PM
  #31
ORIGINAL: Skillhouette
Your supposed to use the shim for break-in I think. Mine came with all 3 installed. I just recently pulled it out after 8 gallons to get some more life in my engine.
Old 06-23-2008 | 10:02 PM
  #32
yeah...same with the STS motor i have, i don't use the shims tho
Old 06-24-2008 | 01:03 AM
  #33
*FULL-REVS*'s Avatar
putting the extra shim in helps drop compression during break in... . just takes a bit of stress off the rod and beerings... remember to pre heat with a heat gun and you will be good as for fuel.... i believe its one shim for 20% and two shims for 30% i run both my GO's on 20% with one shim and OS P3 plugs and they run fantasticly.... hope that helps....
Old 06-24-2008 | 03:50 AM
  #34
Running 2 shims on 20% here, performance is great and running temps of 260f
Old 06-24-2008 | 09:58 PM
  #35
Is this a good deal ? Is it the same engine everyone sells for 209.00 http://www.rc-toro.com/product_info....oducts_id/1273
