RCU Forums - View Single Post - the hyper st PRO thread!
Old 06-24-2008 | 07:56 PM
  #1266
cycleops1966
Default RE: the hyper st PRO thread!
ORIGINAL: supertib
I found my Hyper to have a terrible nose dive tendency off the big jumps.... If you so much as tap the brakes in the air the truck will nose dive super bad......... Having some super strong brakes is going to cause hell if you ever need to try to control the Hyper in the air...
Just because you have strong brakes, doesn't mean you have to use all off them.
I set mine so they will lock the rears in the middle of the straight then back them off to around 50%-60% on the Transmitter
It's nice to know that you can crank more on if you need to.
Phil[8D]
