RCU Forums - View Single Post - need help with battery
Old 06-24-2008 | 09:33 PM
Redback's Avatar
Redback
Default RE: need help with battery
If you are attempting to charge an 8.4 volt battery with a charger that outputs 8 volts the charge time will be eternity[]
To charge a battery requires that the charger supply a higher voltage than the battery.
Also, charging at 1000mA might be risky without an intelligent charger.
Terry
