need help with battery
I need to now the charging time for this battery and charger listed here is the battery and charger specifications
CHARGER BATTERY
wall charger model:HKD8-1000 ni-mh battery 8.4v 2800 mAh rechargable
Input: AC120v 60Hz 29w
Output: DC8v 1000mA
Charging time doesnt have to be exactly just within one hour or so
so please help me your help is greatly apreciated.
THANKS,
Alex Farkas
CHARGER BATTERY
Output: DC8v 1000mA
THANKS,
Alex Farkas
If you are attempting to charge an 8.4 volt battery with a charger that outputs 8 volts the charge time will be eternity[
To charge a battery requires that the charger supply a higher voltage than the battery.
Also, charging at 1000mA might be risky without an intelligent charger.
Terry
]To charge a battery requires that the charger supply a higher voltage than the battery.
Terry
