RE: Whats this
One reason 'pull-pull' systems are used is because a cable, rod, or string under (pulling) tension will remain straight, while a rod or stiff cable under (pushing) compression has the tendency to deflect under load. Pull-pull systems are more accurate and provide faster responses than using traditional push rods. They also allow you to use lighter and more flexible materials.
