RCU Forums - View Single Post - Byron F16 CG?
Old 06-26-2008 | 08:59 AM
KC36330
Default RE: Byron F16 CG?
ORIGINAL: kmtranmd
.........Hopefully, mine at 16.5 lbs with fuel will get off the grass with that alpha stance.
the cheater hole under the bottom sucks down at WOT and in grass can cause you to have problems lifting off, once you get to speed if you'll chop throttle it'll jump off the ground and then back to WOT.
