RCU Forums - View Single Post - There is something wrong with my DL 50cc
Old 06-26-2008 | 03:17 PM
lotech
Default RE: There is something wrong with my DL 50cc
ORIGINAL: craigteffe
1-Make sure you have the diaphram in the right orentation(make sure the nipple is down and the gasket is on the right side. check the meetering level. No trash in or around needle or seat.
2-Make sure you did not overtighten the carb bolts and crack the metal reed housing(check it very closely).
3-Make sure you have a good pulse line going from the carb to the engine.
4-Get a new plug and gap it properly.
All good things to check.Also check no stuff in reeds.Also the reeds have been breaking around here
runs good 1minute same as yours next.Good luck!
