RCU Forums - View Single Post - High idle problem
Old 06-29-2008 | 06:20 PM
phattracker's Avatar
phattracker
Default RE: High idle problem
ORIGINAL: Jamie22
Well got to run the truggy yesterday took the low end back out to factory specs and still idles high
Why dont you try to idle your motor, then try to push the carb closed with your finger. If it idles down when you manually push it in, then I'd say linkage, EPA's. Peace.
