RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
High idle problem
Old 06-26-2008 | 06:15 PM
Default High idle problem
Have a rossi 528x that wont idle down. I turn idle secrew down but still high. Temp were 240 and ran great just wont idle right. Im thinkin it mite be an air leak. Any other thoughts ?
Old 06-26-2008 | 06:22 PM
Default RE: High idle problem
that or your linkages and epa isnt set right
Old 06-26-2008 | 06:27 PM
Nah all thats is done that was the first thing I checked. Carb can completely closed and still idles high as hell lol...
Old 06-26-2008 | 06:28 PM
Nice lookin track btw
Old 06-26-2008 | 06:30 PM
thanks do you have a return spring ??
Old 06-26-2008 | 06:32 PM
slayerphonics's Avatar
Does it idle real high after a high speed run then eventually idle down?
That could be a lean high speed,
How much space is there between the slide and the inside of the carb? should be about the width of a credit card or so.
If thats set right, its gotta be your tune,
You could have used the low speed needle at one point to compensate for an incorrect idle? or vice versa.
Id check the gap,
Then reset my needles and tune the high speed then the low speed.
Old 06-26-2008 | 06:33 PM
No linkage workin great. Can put my vspec on there and it idles just fine.
Old 06-26-2008 | 06:35 PM
Yea the gap looks good. Check the low speed needle to and it didnt change anything. Wouldnt an air leak make it idle high ?
Old 06-26-2008 | 06:36 PM
hum it might be your low speed that has some to do with your idle also try riching it up and hour and riching up your idle 4 hours
Old 06-26-2008 | 06:39 PM
Aight thanks for the info will give it a try tomarrow
Old 06-26-2008 | 06:41 PM
no problem i had trouble with that on my sportworks .26 v2 and i riched up the low speed and it went down
Old 06-26-2008 | 06:42 PM
Yea i still amazed on how much power this motor has lol
Old 06-26-2008 | 06:44 PM
yep they have power but sometime they can be hard to tune lol
Old 06-26-2008 | 06:47 PM
Yea and hard to keep the tires mounted on
Old 06-26-2008 | 06:49 PM
ya thats why you richin the high speed so you can keep them mounted lol
Old 06-26-2008 | 08:17 PM
ORIGINAL: rebelracer246
Yes, give the low end a few hours, it will bring the idel down. Dont run it to lean on the low end, bad things happen to a nitro engine when the low ends to lean.
Old 06-29-2008 | 09:52 AM
Well got to run the truggy yesterday took the low end back out to factory specs and still idles high
Old 06-29-2008 | 12:14 PM
mabuecker's Avatar
My Feedback: (8)
I'd hate saying although sounds like rebuid time ?
Old 06-29-2008 | 06:20 PM
phattracker's Avatar
ORIGINAL: Jamie22
Why dont you try to idle your motor, then try to push the carb closed with your finger. If it idles down when you manually push it in, then I'd say linkage, EPA's. Peace.
Old 06-29-2008 | 07:30 PM
Almost new motor.... Tried my finger but its closed all the way and still idles high
Old 06-30-2008 | 04:59 AM
The only other thing it can be is an air leak then, could be the back plate etc.
Old 07-29-2008 | 02:58 PM
Make sure all your needles are set to factory settings including your idle needle. also apply carb sealant to carb rim as well as backplate area. based on what you said " I pushed the throttle link all the way in" makes me believe your idle pin is not extended far enough in your venturi area to stop it from completely closing thus you are shutting out all air entry into your engine.
Old 07-29-2008 | 03:05 PM
ORIGINAL: Jamie22
Hey I just looked at what you were saying " still idles HIGH"... this is a correction to my earlier response. You may want to first apply carb sealant to eliminate any possible air leaks both on the carb as well as the back plate. However, it almost sounds like your engine may be dirty on inside. I know you said this was a new engine. It may have shavings inside that you need to clean. Since it is new I doubt that you have a piston/sleeve compression issue. Just make sure when you finish running your RC you always turn your flywheel to get your Piston at BDC(bottom dead center) so that you do not stretch your sleeve and loose your compression. Really sounds like an air leak though but I would probably break the engine down and clean it with denatured alcohol and relubricate the internals to be on the safe side.
