RE: Tiger Trainer 40 rudder issues
i found out why the rudder control rod was rubbing. the rod attached to the wood dowel was on opposite sides of the dowel, forcing it into the frame near the exit from the fuse... on to the next issue.... the rudder servo also controls the steering of the front wheel. the bracket is so tight that the wheel doesn't turn freely. what's the fix?
Rob
