RCU Forums - View Single Post - Classic pattern for .20 cu.in
Thread
06-30-2008 | 01:24 AM
55
Roguedog
Feb 2007
939
Norco, CA
RE: Classic pattern for .20 cu.in
Way cool. I've been collecting MK plans and just about every one only has the wing root and Rib W-4. No other rib or former templates. Bummer.
I've been creating ribs by using the Fuse's side view of the wing root as well , then subtracting 3/32 for the skin. The tough part is gettin the the right height of the rib at the wing tip. Since I don't have Profili I copy the root and scale it down to the length of the tip rib than loft the two together to get a 3D version of one side of the wing. At this point I add 3/32" 3d rectangles thru the wing then use the interfere comand to get the ribs. I guess it's the long way around, but I get a 3d verison of the ribs then use the Explode command to get a 2d for laser cutting.
Reply
Like
Roguedog
View Public Profile
Send a private message to Roguedog
Find More Posts by Roguedog
View iTrader Profile
