RCU Forums - View Single Post - Composite-ARF Integral, kinda build thread
Old 06-30-2008 | 09:23 PM
  #719
can773's Avatar
can773
Default RE: Composite-ARF Integral, kinda build thread
Thanks Ryan!
Gear is from Wistmodel, same as whats used on the Prestige. Its as light as ZN gear (95 grams/pair) but stiffer and less prone to delamination failures. Only problem is that its a little flimsy where the axle mounts, you would not want to turn hard on landing or I think you might break them!
What I really like is that the gear mounts across the entire bottom of the fuse, so you don't have that space between the gear halves, this makes the whole setup much stronger.
