RE: Newbie needs help with TT-01:)
Goral: To get a TT-01 sliding..
I would Suggest a Tamiya RZ motor, a 15T Reversible ESC and do the Ball Bearing and alloy propshaft upgrade with a Change to some Hard Compound tyres..
I learned on PVC Tyres, then Swapped to ABS once I had the car control worked out.. Learning on the Slipperiest Compound possible may take longer but your car control will be more advanced then if you went straight for the Easiest compound...
