Newbie needs help with TT-01:)
Hi
I am completly newbie in r/c cars
. I have just bought stock Tamiya TT-01. What I have to change? I want to have a good drift car for good amateur or semi-professional. I think first thing what should be changed is engine??Please give me advice. Thanks
my tt01 setup
gtb/7.5r 19t pinion 61t spur
ball bearings
aluminum shaft and motor mount
ball bearing steering
cf upper deck
sways (blue)
trf dampers with tamiya yellow springs
aluminum 3racing dogbones
rear spool, front ball diff
adjustable upper arms and front links
so i have about 300 dollars in parts not including motor and servo in mine, but it drifts like a dream
ball bearings
cf upper deck
sways (blue)
Hello
I need an advice with the part for my r/c car
Which shocks should i pick??
[link]http://cgi.ebay.co.uk/GPM-Alloy-Threaded-Damper-Shocks-50mm-TT-01-tt01-TT01_W0QQitemZ310054259150QQihZ021QQcategoryZ34063 QQrdZ1QQssPageNameZWD1VQQcmdZViewItem[/link]
[link]http://cgi.ebay.com/GPM-Alloy-Complete-Damper-Shock-SET-B-fits-TAMIYA-TT-01_W0QQitemZ180253082537QQihZ008QQcategoryZ34061QQ ssPageNameZWDVWQQrdZ1QQcmdZViewItem[/link]
[link]http://cgi.ebay.co.uk/Oil-Shock-Damper-4-Tamiya-TRF-HPI-1-10-1-10-Touring-Car_W0QQitemZ120150995837QQihZ002QQcategoryZ140979 QQrdZ1QQssPageNameZWD1VQQcmdZViewItem[/link]
http://cgi.ebay.com/X-Spede-Tamiya-T...dZp1638Q2em124
ENGINE:
Tuned 540:
[link]http://TAMIYA-Mabuchi-RS540-Sport-Tuned-Modify-Black-Motor-23T_W0QQitemZ160248882812QQihZ006QQcategoryZ34061Q QrdZ1QQssPageNameZWD1VQQcmdZViewItem[/link]
Lightly tuned 28T
[link]http://cgi.ebay.com/53983-TAMIYA-1-10-R-C-LIGHTLY-TUNED-motor-28T_W0QQitemZ130163449463QQihZ003QQcategoryZ34061Q QrdZ1QQssPageNameZWD1VQQcmdZViewItem[/link]
SuperStock:
[link]http://cgi.ebay.com/Tamiya-Super-Stock-Motor-RZ-53697_W0QQitemZ380036536673QQihZ025QQcategoryZ4402 8QQrdZ1QQssPageNameZWD1VQQcmdZViewItem[/link]
Super Stock RR:
[link]http://cgi.ebay.com/49260-Tamiya-Super-Stock-Motor-Type-RR_W0QQitemZ260221433279QQihZ016QQcategoryZ34061QQ rdZ1QQssPageNameZWD1VQQcmdZViewItem[/link]
or last one Acto tunef M- special
[link]http://cgi.ebay.com/Tamiya-53251-ACTO-TUNED-M-SPECIAL-Race-Motor-M02-M03-04_W0QQitemZ190224224231QQihZ009QQcategoryZ34061QQ rdZ1QQssPageNameZWD1VQQcmdZViewItem[/link]
Can some of you tell me exacly what parts you have? I mean ball bearings, sways, rear spool, front ball diff etc.
I have one more question is it TT-01 Chassis???
[link]http://www.putfile.com/pic/8310266[/link]
Thank you for help. Cheers;]
ENGINE:
Tuned 540:
Lightly tuned 28T
SuperStock:
Super Stock RR:
CO
I would suggest is to modify the tires, get rid of those rubber tires way to much grip. So go to your hardware store, picking up some ABS Plastic Piping (bring a rim, for sizing)
(not PVC, because if you use PVC there is very little traction and you will just be messing up more than learning, and ABS has the perfect balance)
Swap out those tires, and practice. Then build up from there.
Don't try to learn on a "non beginner drift car"
Please read this it will answer some of your questions!
[link=http://www.rcuniverse.com/forum/m_6327870/anchors_6327870/mpage_1/key_/anchor/tm.htm#6327870]The Beginners Guide to Drifting![/link]
I learn on spray paint caps!
Quick question, I see the TT-01 Type E ball bearings as listed separately on RCmart... does anyone know if they will fit the standard TT-01 chassis?
Goral: To get a TT-01 sliding..
I would Suggest a Tamiya RZ motor, a 15T Reversible ESC and do the Ball Bearing and alloy propshaft upgrade with a Change to some Hard Compound tyres..
I learned on PVC Tyres, then Swapped to ABS once I had the car control worked out.. Learning on the Slipperiest Compound possible may take longer but your car control will be more advanced then if you went straight for the Easiest compound...
