RE: Tiger Trainer 40 rudder issues
Are you talking about where the nose gear goes up into motor mount.
Try removing the nose gear linkage and check it if it is still tight then try lubing it. Also I would use goldn'rod there also it's nice to be able to have that gear give alittle and save on your servo gear.
