Thanks for your support ....I think
http://www.offshoreelectrics.com/pro...?prod=TP-Jolly could be a good choice and I saw clip for this hull with the following setup
Motor: Neu 1521/1D
Batts: Two Thunder Power 6S 4500 Mah
prop: GrimRacer L45x68 Lifter
ESC: Jeti spin200
Speed was 64 mph and acceleration was impressive as soon as boat plane but boat takes some time to be flat on water. I think boat is overpowered and this setup is very expensive… do you think the same.
