Flat Spin To Inverted Flight Stall
Hi,
I seem to be really having a problem generally with inverted flight stalls and nosed in my 3D practice plane this morning - - - again !!!I'm wondering if there's a knack to it that I don't know about but if I come out of a blender into a flat spin and then just want to come out into inverted flight I'm find the plane stalls really vioilently and is very hard to recover from - snapping from a stall one side to te other. I also had it a while ago coming out of a 1 1/2 snap roll (probably too slow) inverted and cost me a plane that time and generally find it much much harder to recover from any inverted stall than one up the right way, is this a normal chracteristic.
I wonder if with the flat turns I should be giving quite a bit of throttle just as I try and come out as at that stage you're stopping the plane from falling and trying to go into normal flight but just don't have enough speed ????
Any help generally on inverted stalls much appreciated !!!!
As I'm typing and trying to work it out I wonder if with normal flight when you stall you just quite happily dip the nose which increases the speed and makes it easy to recover and yet inverted you're concentrating so hard on not giving up elevator to avoid it plummeting toward the ground you're making it harder to recover from and the only thing that you can use is the throttle ???????
