RE: Powerbox Digi Switch Regulator & TP LiPo setup
Hi Amram,
Thanks for the info.
I did some bench testing with the digi switch with fully charged LiPo and when I move fully all the sticks the led becomes slightly orange and then returns back to green, this slight change will not be visible I think in day light but inside a relativelly dark room it is visible. I did some load testing on my LiPo pack and seems ok.
Also after some time (about half an hour) operating the digi switch on the bench setting up throws etc. I switched it off, suddenly I remembered that I had to set up the throttle to elevator mix. I tried to switch it back on following the button sequence and the switch could not become alive. After 3-4 minutes I tried again and it switched on. This fact was very strange and made me to have some doubts about this device.
Are these common symptoms?
Looking forward to your feedback, thanks!
Nikos
