RE: Pro 4 drifting setup
1. What are ABS tyres ??
2. I have a spool and one way would the best setup be a front one way and a rear spool ?
3. Spring Tension means softer easier to drift + what do you normally run front softer for more steering control?
4. What motor do you suggest ?
5. What about rear and front toe what is the average you run ? stock runs with 3 degree toe in rear and 2.5 degree toe in front.
6. What about kickup ?
