Pro 4 drifting setup
Hey boyz and girlz, i have a Pro 4 sitting on my shelf collecting dust, i always wanted to convert it to a drfit car but never found setups.
I read that the Pro4 actually is a great car for drifting, i also have all the hpi hop ups for it so all i need is a good setup.
Thanks for looking
Thanks for looking
i mean do you run sway bars? how much toe in out etc... springs soft, hard, kick up etc...
What are the best drift tyres for the Pro 4 ?
CO
All of it is personal preference;
[ul]
-ABS Tires
-Differential Tighten or Lock
-Spring Tension Front/Rear Ratio
-Performance Oriented Motor
-Pinion/Spur Gear Ratio
-Aluminum & Graphite Parts
[/ul]
Hope it helps
[ul]
-ABS Tires
[/ul]
Hope it helps
1. What are ABS tyres ??
2. I have a spool and one way would the best setup be a front one way and a rear spool ?
3. Spring Tension means softer easier to drift + what do you normally run front softer for more steering control?
4. What motor do you suggest ?
5. What about rear and front toe what is the average you run ? stock runs with 3 degree toe in rear and 2.5 degree toe in front.
6. What about kickup ?
