RCU Forums - View Single Post - A glue question
Old 07-03-2008 | 10:26 AM
daven
Default RE: A glue question
I use gorilla glue for formers, landing gear plates, firewalls, and wing bolt supports. It works good in areas that are internal to the plane. Always clamp when using it, and keep an eye on it for the first hour as it will foam up. Just wipe any excess away with a small piece of paper towel. I think it says that it will dry in 4 hours, but I always give it at least overnight. Very strong glue, and what thing I like about it, is that it will stick to laser cut charred wood much better than epoxy.
For your first kit, I'd stick with the glue you have, and if its not fast enough try some CA. Thin if you have a snug fit, and medium or thick if you have a small gap.
