ORIGINAL: Redharris
These are All Useful Tips guys.....
Good Work....Keep em Comming....
Here is another...
Another Use for Baking Soda...
This tip is for stripped out holes in plastic parts.
First remove the screw from the stripped hole.
Take baking soda and fill the hole. Once hole is filled,
put one or two drops of CA glue on the hole filled with baking soda.
Once glue is dry, take a small drill bit (just slightly smaller than the screw)
and drill out the hole. You are now ready with a new, perfect non stripped hole for your screw.
Good bloody heck, does this trick work! Tried it a while ago and I've had the screws in and out a few times since, and I think it's even stronger than it was originally!
