RE: DL-50 engine
When you come in for a landing shut the engine off and check for bearing play by grabing the prop at the ends and push one side in and the other side out to see if you have any play in the bearings,
We had at are club Two DL engines that had bad casing and the bearings and crank was loose in the engine from that,
