RCU Forums - View Single Post - ring and pinion strippage
Old 07-03-2008 | 09:09 PM
wookie457
Default ring and pinion strippage
Hello all, I've been having a little bit of a nagging problem [>:] Last three times I've ran my Eldorada I've stripped the ring and pinion in the rear diff all three times. The last time it did it I thought [&o] I had it solved, I set up the lash like you would in a full size diff taking out all side to side movement in the diff assembly. About half way thru the 2nd tank, I heard the very bad sound of clicking coming from rear again. Tore down the diff and the ring was trashed, but the pinion made it without chipping or loosing a tooth. I can tell by the wear pattern on the pinion that it was meshing perfect. I know the ring is made of steel, but three of them in as many runs[:@], I only have so many hairs on my head to pull out. Anybody had similar problem?? I am using Lucas Oil Synthetic grease for lube, and the front diff hasnt givin any problems. I had an extra ring on hand, but reluctant to run it until gets on my bad side and I want to kill it.
