RE: ring and pinion strippage
bro, change the bearings and maybe the case, there may be some play in it somewhere, i havent had a problem with any of mine, acutally i did, a while ago, the front diff on my eldorada but hasnt happened since. I had a problem with my rs4 and i ended up changing the diff housing and bearing on the pinion gear and its been fine since then also.
