RCU Forums - View Single Post - OS FXi 46 Engine cutting off issue
Old 07-03-2008 | 10:39 PM
nobodytwo's Avatar
nobodytwo
Default RE: OS FXi 46 Engine cutting off issue
Sounds like you may have gotten the lines going to the wrong places. Try looking behind the engine you will see three lines coming from the fuel tank. The top line is the "fill" line. The line on the same side as the needle valve should be the "fuel" line going to the needle valve. That leaves the other line going to the muffler as the "pressure" line.
Happy Landings!
