RE: OS FXi 46 Engine cutting off issue
Thanks for your fast response.
I have everything in order when it comes to my fuel lines. I will recap tha way the metal elbows are inside the tank.
The fuel line inside the tank in a straight metal tube with the silicone tube on it as well as the clunk. Its on the bottom.
The fuel line with the shortest elbow in the refil line and its pointed down.
The fuel line with the the longer elbow is pointed straight up.
I also made shure the cap on the fuel tank is well tightened.
I hope this helps
