RCU Forums - View Single Post - OS FXi 46 Engine cutting off issue
Old 07-04-2008 | 07:46 PM
Mikecam
Default RE: OS FXi 46 Engine cutting off issue
ORIGINAL: jeckelbro
Thanks for your fast response.
I have everything in order when it comes to my fuel lines. I will recap tha way the metal elbows are inside the tank.
The fuel line inside the tank in a straight metal tube with the silicone tube on it as well as the clunk. Its on the bottom.
The fuel line with the shortest elbow in the refil line and its pointed down.
The fuel line with the the longer elbow is pointed straight up.
I also made shure the cap on the fuel tank is well tightened.
I hope this helps
I may be misunderstanding you. Your line in blue, The Carb line with the clunk is the middle outlet in the stopper. The top outlet is the vent and the bottom outlet is the fill line. I'm not sure if your saying the line with the clunk is at the bottom. Again I may be misunderstanding you. Good luck.
